Go Back   Automotive Forums Car Chat > Nissan > Pathfinder | Terrano | QX4 | Xterra | Patrol | Safari | X-Trail
Pathfinder | Terrano | QX4 | Xterra | Patrol | Safari | X-Trail Nissans greatest 4WDs and SUVs
Old 09-14-2004, 06:13 PM
chadl chadl is offline
need help fixing codes P0325 & P0151:
Check engine light has been on for a couple days now and I had to bring it in for an emissions test--obviously it failed and these are the reasons why:
P0325: Knock Sensor 1 Circuit (Bank 1 or Single Sensor)
P0151: O2 Sensor Circuit Low Voltage (Bank 2 Sensor 1)
Does anybody know what to do??
It's an Xterra SE if that makes any difference.
Thanks!!
Old 09-15-2004, 10:03 AM
OffroadX OffroadX is offline
Send a message via AIM to OffroadX
Re: need help fixing codes P0325 & P0151:
Ignore the knock sensor code, it's not critical and will not show up on its own.
02 sensor is the upper one on the driver's side.
The service manual says a problem with any of the following could trigger the code:
Front heated oxygen sensor
Front heated oxygen sensor heater
Fuel pressure
Injectors
Intake air leaks
What year is your X?
Old 09-27-2004, 03:14 PM
02'
I had the dealership fix the O2 sensor and everythings cool now. It was under warranty (I have an extended one up to 100k)
Thanks.
