How do i remove the grill of my 2002 silverado so that i can put in a stainless bowtie and clear corner lights.thanks
No need to remove the grill for the lights. Just unfasten the two bolts holding them in directly above the headlights.
The grill is pretty easy. All you should need is a flathead screwdriver to pop the plastic rivets out and I believe there a few other bolts to unscrew. I've never done it so I can't say exactly how to.
*Under Construction - New sig to debut* |
Re: How to remove the grill
I think after popping the pastic rivets out at the top, there are 2 little plastic screw things at the bottom on each side, they might be at the top also, then you just pull it out.
1998 ECSB Z71
Whelen LED's Kenwood 2-way "BIG 3" 2500+ watt audio ![]() |
what he said ^^^ also, the ends of the grill shell are kept in place by two metal clips, one on each side (easiest thing to remove)
Thanks Guys It was Easy and the lights and stainless bowtie look great!!
