white faced guages
is it hard to get the instrument panel out of a 94 z28? i got a set of reverse glo guages. has anyone here ever done this?
Re: white faced guages
lol i was wondering the same exact thing i was planning on doing the same to my camaro, ill just wait for the answer...
its not hard at all. you have to remove the dash from the cd player over...
*Better power-to-weight ratio than a C6 corvette* |
what do you mean?
so i remove the bezel from around the radio and ac controls and the trim around the inst panel should just pop off shouldnt it?
can someone dumb it out for me...
diablo when im done ill take a road trip and come and change yours ok
you have to remove the dash around the radio. then you have to pop up the dash pad (on top, under the windshield) on the driver's side. i think there are three clips that you have to pop out. you have to remove the driver's a pillar piece and the dash panel under the steering column. once you get all that stuff out of the way you can remove the trim piece that goes all the way around the instrument panel and the HVAC controls. once you do that, than you can remove the instrument cluster, which unbolts as an assembly. you remove the clear plastic cover, and u have to make sure that you remove the factory gauge overlays. also, make sure that you note where the guages are.
there are probably steps im missing cause i did it a while ago...
ok thanks
so you can also change the milage easily too right?
i doubt it diablo, i tried setting my brothers mileage in his trans am at zero when we had a new motor and transmission put in it, cause it had almost 240,000 miles on it. i couldnt turn the #'s all i could do was go to a junk yard, i did find one with 20 some thousand miles on it.
the numbers are either gear driven (third gens and earlier) or computer controlled (most fourth gens). it is possible but you have to completely break down the cluster and rip apart the number cylinders, and put it back together at a different reading...
you can change the numbers... you just need to take them apart from one another and set them back in the mileage you want...
also would anyone like the link to face gauge overlays that you print from your computer???
![]() 95 Z28 Black on Black on Black. Mods: 355CI and lots more... Originally Posted by Mordant I'd say if they ask about material possessions then it's fair game to ask them what kind of underwear they wear, may as well get both sides expectations on the table as soon as possible. |
somehow i dont think those would have the same effect as the ones i got...
Re: Re: white faced guages
