Go Back   Automotive Forums Car Chat > Toyota > Pick-Up
Old 09-14-2004, 12:58 PM
Jaron Jaron is offline
22R Carb problems??
I have a 1986 Toyota 4x4 with a 22R engine. When I first start the truck it accelerates poorly, smells like fuel and surges while at idle. Once the truck gets warmed up I can turn it off for 20 to 30 sec and start it back up and everything is fine. I have changed the fuel filter/plugs/rotor/cap/air filter/PCV valve and thermostat. Any other ideas would be greatly appreciated.
Old 09-17-2004, 10:45 PM
xtoyotacorex xtoyotacorex is offline
Re: 22R Carb problems??
try a can of carb medic-spary the hell out of the carb, that will usually release sticky valves, believe it or not that is usually the case, escpecially if it only idles erratically in the morning when you start it. check if your EGR valve is leaking, and all the vacuum hoses are tight. Maybe sticky choke??? Adjust your valves and set your timing, before you do anything ealse, get that out of the way. Good luck!
Old 10-13-2004, 12:50 PM
Stubbs40 Stubbs40 is offline
Send a message via MSN to Stubbs40 Send a message via Yahoo to Stubbs40
Get some valve cleaner. That will most likely help with your ideling problem too.
Old 10-13-2004, 12:52 PM
this should help
Old 10-29-2004, 04:18 PM
ZachM61 ZachM61 is offline
its possibly your fuel pump, my truck would have trouble starting so i poured some gas into the carb and it started right up also it would drive fine for a while but then it would start to surge.. i replaced the fuel pump and it runs fine now..
Old 08-01-2005, 07:57 PM
71 C10 71 C10 is offline
Jaron, I have a 1982 Toyota 4x4 with the 22R. A while back my truck began to idle rough and at times cut off. Most times it seemed to idle perfect, then for no apparent reason it would idle rough, smell of raw gas and belch black smoke out of the tailpipe. I too tried everything that I could think of like fuel additives, choke cleaners, and most of the things that you did. Nothing seemed to help.
Look at your carb on the side that faces the head. If yours is like mine you will see a small cover with phillips head screws and a vacuum line running to it. It is a second or auxilliary accelerator pump. Before disturbing the small cover, pull the vacuum line attached to it and see if you smell raw gas in the line. If you do, here's the next step. Clearance is tight so will need an offset phillips head screw driver or a bit for a 1/4 ratchet to remove the screws. When the screws and cap are removed, you will find a thin rubber diaphram with a spring and plunger affair. When I pulled the diaphram out of mine it had a big crack in it. I bought a replacement at the Toyota dealer (Couldn't find one at an aftermarket parts store). I can't remember exactly how much the part was but I think in the high 20's. Put the new diaphram in spring side to the carb, put the cover in place, replace the screws and vacuum line and you should be in business. After replacing the diaphram I have not had a minutes trouble.
I hope this helps.
Eddie
Old 08-02-2005, 07:44 AM
fourwd1's Avatar
fourwd1 fourwd1 is offline
AF -Advisor
That diaphram is a common problem on these carbs.
84 4Runner - ARBed 5.29s F&R, 4.7 & 2.28 t-cases, Chevys, AP x-over, BudBuilt x-member, 2" drv trn lift, 36" TSLs, 30 spline Longs
80 something p/u - Buick 231 V6/TH-350 trans, Holley 4 bbl, Weiand intake, dual batts, dual tanks ...
89 4Runner - stock
2000 Isuzu Trooper + 2010 Sonata
Old 01-04-2006, 08:42 PM
macdad626 macdad626 is offline
I Just Bought An 86 With The Same Problem. It Will Run Fine Than Going Down The Road It Will Start Surging When I Give It Gas And Cut Off Then After Dying Out I Have To Give It Gas And Rev It High To Get It Going Again Does This Sound Like A Carb Problem ??????? If So What Was The Fix For You Guys Thanks
~justin
Old 01-12-2006, 12:20 AM
greenhorn greenhorn is offline
Might be grasping at straws here but it sounds like a faulty egr to me
