Old 09-14-2004, 12:37 PM
Clueless1975 Clueless1975 is offline
Question Keyless Remote Programming
Anyone out there know how to program a keyless entry remote on a 2003 Town and Country? Its got to be easy enough for me to do myself, if I can just find out the process.
Old 09-15-2004, 08:04 PM
mike2004tct's Avatar
mike2004tct mike2004tct is offline
Depends if you have the Sentry security system or not. If you do, you need two (2) working units already programmed to program up to 6 additional keys. If you only have one key, you'll need to see a Dealer for programming, as factory codes need to be downloaded into the receiver.
(My Van only came with one key, I got an unprogrammed blank with it,but couldn't program it)
From "The" Owner's manual, ONly if you have the Sentry system;
Insert the 1st key and turn the swith to ON for 3 seconds but not longer than 15 seconds,then remove it. Insert the second key and turn to ON for 3 seconds but not longer that 15 seconds. After 10 seconds,a chime will sound and the Theft Alarm Light will flash. Turn the key to off and remove it. Insert the new unprogrammed key and turn the switch to on within 60 seconds.After10 seconds,a single charm will sound. The Theft Light will stop flashing, Turn on for 3 seconds,then turn off. The key is now programmed.
Old 09-16-2004, 07:06 AM
dmburrows dmburrows is offline
This is for the keyless remote, not the keys. The procedure should be in the owners manual.
Old 09-19-2004, 09:41 AM
caravanbob caravanbob is offline
Re: Keyless Remote Programming
If you already have a remote that works for that vehicle, you can program another one to also work with it yourself.
If you don't have a working remote, you'll need to have the dealer program one for you.
