Go Back   Automotive Forums Car Chat > Lincoln > LS | MKZ
Old 09-14-2004, 10:49 AM
01 Lincoln LS 01 Lincoln LS is offline
Send a message via AIM to 01 Lincoln LS
shop with authorized PCM codes...?
Ok i went to cerritos lincoln/murcury dealor and was talking to some of the mechanics. I was asking them if they had ever tuned a lincoln ls before, they said because all tuning is done at a tune shop out in pomona or something. They said there is an authorised shop with all the codes and everything that can tune. And that any good shop can do a custom job to get ur SC or TC in and this shop can tune it all and change computer stuff. but you will be left with a void warranty because of the custom job, but if u want to change the computer(not chip) the authorzed shop can do that and u will not void ur warranty. IS THIS BS OR WHAT?????? Are there tuning shops out there with all the codes(not cracked) or are these dealorship mechanics BSing me.
Old 09-14-2004, 04:48 PM
Quik_LS's Avatar
Quik_LS Quik_LS is offline
Send a message via MSN to Quik_LS
The LS was the first Ford to use the new 'Black Oak' processor - which uses a compiled language as its operating system. This is unique - as PCMs in the past stored tables of sensor data in a fixed location - allowing 'tuners' to simply change those values to change the behavior of the engine. In the LS the location of the data table change with every compile - so there is no easy way to adjust these values - you have to reverse engineer the code - which will change for every PCM level.
Apparantly, SuperChipsCustom http://www.sctflash.com/main.php has done the black oak, and even an LS - 14rwhp gain.
Problem is - you have to send them your PCM and they reprogram it. So if you ever go to the dealer - they can not use there standard tools to diagnos the car - and your out of luck....
If you ever need a PCM reflash to correct a TSB - your out of luck - or you loose your programming.
Quik LS - Austin, TX
more, more, more.....
#0018 ESP SCCA solo2
LLSOC.com - President
see my mean LS
see my Lotus Esprit - Quiker
Old 09-14-2004, 10:52 PM
bill05's Avatar
bill05 bill05 is offline
Send a message via ICQ to bill05
The guy checking me in at my local dealership told me Diablo made an LS chip... which I don't believe is the case. Pretty scary, since he's in charge of the entire service department.
2000 LS V8 SPORT
Black · Charcoal Interior · Sylvania Silverstars · Sirius Satellite Radio · LS Koncepts Eyebrows · Borla Stainless Steel Cat-Back · Black McClaren Grill- Upper & Lower · Black Surround · LLSOC CAI with KKM Filter · Eibach Springs · Red Calipers· SCT Tuned
Old 09-15-2004, 12:04 PM
Quik_LS's Avatar
Re: shop with authorized PCM codes...?
you are correct - none of the major 'chippers' do - the LS/T-bird was too small of a market for them. The good news is that the newer Fords will be carrying the same type of PCM (2002+ LS) so they'll crack it for the Mustang and F150. It may leave us 00-01 LS owner out....
see my mean LS
Old 09-15-2004, 12:52 PM
ok i was reading some other forum, what about that guy who turboed his car, the guy who put it behind his rear bumper. how did he have access to all the software?
Old 09-15-2004, 09:19 PM
Quik_LS's Avatar
I had quite a long discussion with that guy - gotta hand it to him. Here's what he told me:
- didn't crack the PCM - but didn't have to as appartently there was even auto adjustment in the fuel to compensate
- he isn't running the turbo anymore
I had a hard time believing you could turbo the LS if you could control the fuel/air/spark.....
see my mean LS
