Recently I had driver side front and passenger side front hub assembly's replace, and I realized that was a little expensive. It seems the driver's rear is now going, I was wondering if there were any detailed guides online on how to replace the item. I have already acquired the part; sorry to say I am not mechanically inclined.
Re: Rear Hub Assembly
if you buy a chilton book on the car it walks you through it. honestly its rather easy to do the rears if you are doing the whole assembly. take off the brake system then undo the four bolts in the back of the assembly. then you need to push the assembly through towards you. you will probably need a hammer and a peice of wood to do this. then just reinstall in reverse. the only hard time I had was lining up the hub bolts again. good luck!
Your help is much appreciated, I got the problem fixed for when I did this post, though I paid someone to do it. Oh well other one is going now as well, so we're replacing #4 now. Thank you
