Go Back   Automotive Forums Car Chat > Honda > Prelude
Old 09-14-2004, 08:48 AM
futball22 futball22 is offline
engine light is on and wont idle.
After doing a engine swap, I found that my car once its warmed up wont idle, and after it gets to near running temp, the check engine light comes on. Other than that it runs great. Would this be caused by the o2 sensor on my exhoust maybe not working properly? or is there any other opinions? thanks alot.
Old 09-14-2004, 11:16 AM
AcesHigh's Avatar
AcesHigh AcesHigh is offline
Prelude Guy
Send a message via AIM to AcesHigh
Re: engine light is on and wont idle.
Check the CEL code. And what do you mean it won't idle, it has an unstable idle?
1993 Mazda Rx-7 Touring
Ricer Extraordinaire
Old 09-14-2004, 06:01 PM
Whenever the clutch is in or its out of gear and just left sitting there, after it has reached running temp, it wont idle. But while its warming up with the auto choke on it will idle fine. How do i check the CEL code?
Old 09-14-2004, 06:25 PM
SiGNAL748's Avatar
SiGNAL748 SiGNAL748 is offline
Send a message via AIM to SiGNAL748 Send a message via MSN to SiGNAL748
You mean like, the rpms surge?
Old 09-14-2004, 06:38 PM
Whatever you call it when instead of when your rpms go down and stop at about 800rpm, it just goes to zero and stalls.
Old 09-17-2004, 07:20 PM
Oddball2559 Oddball2559 is offline
I had a similar problem with my 4th gen only my rpms would surge, but my engine light still came on at running temp. Anyway it turned out that I had a bad vacuum line and that fixed it right up.
Old 09-18-2004, 10:09 AM
do you know which vacume line it would be? Thats a very posible problem, concidering I just changed engines and maybe didnt hook up a vacume line properly.
Old 09-20-2004, 11:35 AM
b20a5lude b20a5lude is offline
Please read this and help me if you can!!!
I rebuilt my 1988 prelude engine and am having problems with mixture! It is a B20A5 engine,fuel injection 2.0l. Symptoms:
With no check engine light:
-runs rough
-as soon as it hits 3750 rpm it has a definate iBIG JUMP in horse power!!!!
-smells like it runs rich
After check engine light comes on:
-runs better!!!
-no big jump in hp @ 3750 rpm
-does not smell as rich
Apon rebuild I replaced the o2 sensors with new NGK o2 sensors, new distributor cap and rotor, plugs(platinum), ect...
please help me !!!!!!!!!!!!!! The biggest thing I noticed is the gain of HP when the light is off (weird)????? Could it be the o2 sensors ...egr valve??? pcv valve???? I confused????
Thank you
Steve
