Go Back   Automotive Forums Car Chat > Oldsmobile > Aurora
Old 09-14-2004, 06:03 AM
miguel2112 miguel2112 is offline
engine cooling fans
cooling fans not comming on when engine gets hot 225 deg etc, they will come on when a/c is on, could it be the temp sender,where is it?any thoughts,thanks
Old 09-14-2004, 11:42 AM
97 silverbullet's Avatar
97 silverbullet 97 silverbullet is offline
Send a message via AIM to 97 silverbullet Send a message via Yahoo to 97 silverbullet
Re: engine cooling fans
did you rip off your air dam under the bumper?
[On his running for California Governor]
It's the most important decision I've had to make since 1978 when I decided to get a bikini wax.
-- Arnold Schwarzenegger
Politics is not a bad profession. If you succeed there are many rewards, if you disgrace yourself you can always write a book.
-- Ronald Reagan
"I wrote a book"
--Bill Clinton
Old 09-14-2004, 12:23 PM
BigDaddy Royster's Avatar
BigDaddy Royster BigDaddy Royster is offline
I had the same problem and it was a bad temp sensor. Instead of replacing the sensor, I simply hot wire the cooling fan using a toggle switch. Now, I just turn the toggle switch when needed. Good Luck.
95 Olds Aurora (Northstar 4.0L w/Autobahn Package @ 250+ HP)
98 Olds Bravada (4.3 Vortec)
95 BMW 740 i (salvage purchased from insurance co. to be fixed up)
Check out other pictures of my RoRa at WWW.CarDomain.COM
BigDaddy Royster
Old 09-23-2004, 06:28 AM
replacedtemp sensor fan come on now but it seems they have a low output. I thought that before when they came on they where really blowing hard,any thoughts?
Old 09-23-2004, 10:45 AM
rodtice's Avatar
rodtice rodtice is offline
they are variable speed, they change speed according to engine temp. Get it real hot and they crank.
Old 09-27-2004, 09:17 AM
1995oldsaurora 1995oldsaurora is offline
Re: Re: engine cooling fans
where is the temperature sensor ??? i'm having the same problem..
Old 09-27-2004, 10:19 PM
bustedratchet bustedratchet is offline
Check the wires running into the 3 relays on the center of the firewall. On my son's 95 it was the dark green wire (pcm to relay)that fell out when I tugged on it.
