Go Back   Automotive Forums Car Chat > Jeep > Grand Cherokee | Grand Cherokee SRT8
Old 09-14-2004, 02:35 AM
lhavelas lhavelas is offline
oil with teflon?
hallo to everybody from greece
iwant to ask about the oil with teflon. here in greece we have accesional for the oil of the engine with teflon. are good for my grand cherokee 96'
sorry for the English
Old 09-14-2004, 12:49 PM
msrjeep msrjeep is offline
Send a message via AIM to msrjeep
Re: oil with teflon?
no, it clogs oil filters and causes other problems. telfon must be bonded to metal surfaces by baking at extremely high temperatures. DuPont the inventor of Teflon tried to prevent the few oil companies from buying it and they advise against it's use. Notice how no major oil producers offer teflon "enhanced" oils. If there was benefit, they would be doing it as well.
Old 09-14-2004, 12:53 PM
there are so many "peformance enhancers" out for cars promising less wear or MPG gains, things like the "tornado" an aluminum finned insert that is supposed to make air flow better. if it worked and you got thier promised 10% increase in fuel economy or whatever, don't you think major manufacturers would be using that technology from the factory? it would be quite a cheap improvement for fuel economy. if it sounds too good to be true, it probably is.
Old 09-14-2004, 10:52 PM
JDPascal JDPascal is offline
Please listen to msrjeep here and save your self money and future problems!!!!!!!!!!!!!!!!!!!
If I used every product that proported to increase fuel economy by "10%" my Jeep would be a money maker. The more I drive it the more I make - haha. Might even put the gas companies out of business.
JD
JD
Old 09-17-2004, 10:04 PM
oh yeah if you are looking for something to slightly reduce wear or increase oil change intervals, use a good quality synthetic motor oil. Mobil 1, Amsoil, Valvoline, and Castrol all make good full synthetics. Use a high quality oil filter such as Puralator, Mobil 1, or Amsoil filters. Then you can just change your oil filter and replace the oil you lose while changing that for a few intervals. If you change your standard "dino" oil every 4 months, it won't oxidize, separate, and "sludge" so your results will be similar. A quart of standard oil is $1-1.75. A quart of full synthetic is $4-6. Do the math and do whatever you feel is better!
Old 09-17-2004, 10:08 PM
who likes greek?
Όχι, τεφλόν θα φράξει τα φίλτρα πετρελαίου και προκαλεί άλλα προβλήματα telfon πρέπει να συνδεθεί με τις επιφάνειες μετάλλων από το ψήσιμο στις εξαιρετικά υψηλές θερμοκρασίες. DuPont ο εφευρέτης του τεφλόν προσπάθησε να αποτρέψει τις λίγες επιχειρήσεις πετρελαίου από την αγορά του και συμβουλεύουν ενάντια στη χρήση it's. Παρατηρήστε πώς κανένας κυριότερος παραγωγός πετρελαίου δεν προσφέρει το τεφλόν "enhanced" πετρέλαια. Εάν υπήρξε όφελος, θα το έκαναν επίσης.
