Go Back   Automotive Forums Car Chat > Isuzu > Rodeo | Passport | MU
Old 09-14-2004, 01:08 AM
jscrock jscrock is offline
Fan for AC/heat
HELP!!! The blower motor only works on high for ac and heat, why does it only work on high, if the whole unit was defective shouldn't it not work at all.
Old 09-14-2004, 02:24 PM
Puna Puna is offline
Re: Fan for AC/heat
I dont know if it the same but on my 2000 Silverado the fan wasnt working on the 1 & 2 speed read a post in the SILVERADO forum (Hvac 2 not working) or something like that. Recommended changing the blower motor resistor, whick was located near the blower. Did it myself for about 20 bucks for the part, now it works fine. If the Rodeo has the same kind of set up and I see why not, my 94 mustang did, the fix shouldnt be to bad.
Hope this helps
Old 09-15-2004, 07:34 PM
2eyefishclaw's Avatar
2eyefishclaw 2eyefishclaw is offline
Send a message via AIM to 2eyefishclaw Send a message via Yahoo to 2eyefishclaw
Re: Fan for AC/heat
resistor is bust you can change just the resistor it wil work for a while and burn out again or you can replace the blower and resistor and all will be good
there is an alternative to replacing the resistor remove it break the plastic off of the sides of it and resolder the thing back together
