Old 09-13-2004, 09:56 PM
n8s95gsx n8s95gsx is offline
Unhappy What does this do?
My car is in the process of being rebuild at a local performance shop right now and I miss her more and more every day, but she will be comming home soon ( WOOOOHOOOO ) But gettin to the point they gave me a call today and suggested that they install a balance shaft eliminator kit. Now it was only $50 so i just said hell whats another $50 right. What does this part i just bought do???
Old 09-13-2004, 10:02 PM
kjewer1 kjewer1 is offline
AF - Advisor
Re: What does this do?
Eliminates the chance that the front bshaft will sieze up and toss the bsahft belt, thereby taking out the main timing belt, and the chance that the bearing will spin and come apart ruining other bearings and taking out the turbo. It removes a couple pounds of rotating mass, but its main function is to make the motor more reliable.
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 09-14-2004, 02:47 AM
AF - Advisor
If the motor is being rebuilt there should be no extra charge, since there is no extra work involved. In the car though, and I can see why. Its a LOT of work to get the bshafts out with the motor in the car. A good bit more work even if you are already sapping the oil pump in the car (but the pump swap is 90% of it).
Kevin Jewer
Old 09-14-2004, 07:22 AM
Thanks for the info!
Old 09-14-2004, 04:22 PM
BoostedSpyder's Avatar
BoostedSpyder BoostedSpyder is offline
Send a message via MSN to BoostedSpyder Send a message via Yahoo to BoostedSpyder
and the removal of the balance shaft is said to free up 8-10 HP too...
