Old 09-13-2004, 06:17 PM
valo valo is offline
85 brake lights not working
I replaced a blulb that was out on the left middle
of the break light box. Nothing. I then replaced the
brake light switch behind the brake pedal. Still nothing.
Any ideas? Turn signals work. Hazards work. When
I turn the headlights on, they all light up in the back
just nothing changes when brakes applied.
DJ
Old 09-13-2004, 06:24 PM
tweekin tweekin is offline
Send a message via Yahoo to tweekin
Re: 85 brake lights not working
engine code 17? what is it?
Old 09-13-2004, 07:31 PM
yogi_123rd yogi_123rd is offline
Did you check your fuses?
Old 09-13-2004, 11:56 PM
Re: Re: 85 brake lights not working
yes
Old 09-14-2004, 07:13 PM
I've just looked through the wiring diagram in the Hayes manual. The circuit goes like this:
Hot [20A fuse]
Brake switch
|------ center mounted Stop light --- [ground]
Turn/Hazard Switch Assembly
|------ Left/Right rear Stop Lights --- [ground]
Your problem could either be bad wiring or the Turn Hazard Switch assembly is bad. It will depend on if the center mounted Stop Light is working.
Old 09-15-2004, 09:46 PM
Hot [20A fuse]
Brake switch
It was the connection between the switch and the turn signal assembly. A wire going from the brake switch and the small harness going up the steering column was broke. I rewired it and all is well.
valo
