Go Back   Automotive Forums Car Chat > GMC > Jimmy
Old 09-13-2004, 04:56 PM
Enginegone Enginegone is offline
StartingProblems 1997 Jimmy
I have started to have problems staring vehicle.Acouple of months ago
couldn't get key out of ignition.Had to take plug out of bottom cover
on steering column and push up plunger on what ithink is the park
interlock to get key out.Couple of days ago problems starting.Turn
key to run no lights on dash no relays.Will turn over but no start.
Anyone have any experience with this?
Old 09-13-2004, 06:57 PM
Jeremy-WI Jeremy-WI is offline
Re: StartingProblems 1997 Jimmy
Check for power on the pink wire of the ignition harness with key on. If there is no voltage check underhood fuses, if fuses all check out(especially the IGN fuses) you may need to replace the electrical portion of the ignition switch
Old 09-13-2004, 07:09 PM
Re: Re: StartingProblems 1997 Jimmy
Thanks for help all fuses good wiggle wires get lights back and start.
Will try replacing switch seems to be a common problem
