Go Back   Automotive Forums Car Chat > Mazda > RX-7
Old 09-13-2004, 04:26 PM
NuTbAgSaN's Avatar
NuTbAgSaN NuTbAgSaN is offline
Send a message via Yahoo to NuTbAgSaN
Question hot...
nice title...
anyway, i finally got tags and whatnot. so i been driving around a bit and whatnot.
well first off, i know i have an exhaust leak or two, because i still havnt fixed my 5 & 6 ports (doing it tonite when it cools down) and it smokes a bit when it gets to 6krpm. and i can see exhaust coming out the sides of the car. anyway, after driving maybe 10 min or so i came back home, and there is a ton of heat comming off the tranny, or the area at least. like the shifer and everything was quite hot, and it was pretty hot inside, even withe windows down and sunroof open. and its not especially hot out today or anything.
is this heat just caused by the exhaust leak? i mean it is a pretty bad one.
by the way its just the gray smoke which i believe is nothing too abnormal, except there is a lot at 6k+. like a ton. but this car has never been drivin hard or reved high, which would be the cause of the sticky ports.
really no smoke at all under 5krpm.
changed the oil. it had synthetic, i put in gtx 20-50.
well that was my day. basically just wanted to know if the exhaust leak would be causing the heat.
still need a new shift knob if anyone has one lying around...mine is really loose, its all jacked up. im so broke now.
Old 09-13-2004, 05:19 PM
J-Rat's Avatar
J-Rat J-Rat is offline
Send a message via AIM to J-Rat Send a message via MSN to J-Rat
Re: hot...
Sounds like your shifter boots are all gone. Pull up the shifter surround and look..
1988 10th AE Edition TII
More mods then you have.
Old 09-13-2004, 06:34 PM
NuTbAgSaN's Avatar
your right. i seriously need a new boot. im really broke right now however. hahahahaha
Old 09-13-2004, 10:46 PM
Soyo's Avatar
Soyo Soyo is offline
Send a message via AIM to Soyo
Re: hot...
so what did you get anyways? maybe I missed the thread that you talked about the car you bought or something? who knows...
1989 RX-7 TII --- Just got rebuilt and street ported
RB 3" dual exhaust, BNR stage 1 modified factory turbo, FCD, S-AFC II,
720cc secondaries, Aftermarket Turbo inlet duct w/K&N, Hawk HP+ pads
HKS Blow-Off Valve, Stainless brake and clutch lines
Old 09-14-2004, 10:31 AM
NuTbAgSaN's Avatar
nah, i didnt start a thread on it. i ended up getting a pretty good deal on a 90 gtu.
and actually i took it out last nite and it was running much better. i took it out on the highway...wow...and drove it much longer and it didnt get as hot as before. still got warm, but not bad. smokings not so bad. i think the oil helped.
not perfect yet, but its so much freakin fun to drive.... im in love
