Go Back   Automotive Forums Car Chat > GMC > Sonoma | S-15
Old 09-13-2004, 01:27 PM
kplourde kplourde is offline
Angry Big Heat Problem
We have a 2001 GMC Sonoma that has a major heat problem.
All controls are in off position and windows are open, (we bought a thermometer to read the temp in the cab just like this),,,, highest temp 119F (48.5c) with the windows up and all controls in off position the highest temp we read was 109F (42c).
Now we found out the other day that if we have the control in the defrost setting it stops the heat.
We have taken it to 2 GM dealers and both say its normal, one service tech called the GM plant and they say its normal and there is nothing they can do about it.
Does anyone know of this problem and how did you deal with it??
Old 09-19-2004, 07:46 AM
GMMerlin's Avatar
GMMerlin GMMerlin is offline
I know stuff
Re: Big Heat Problem
The HVAC system is designed to bring fresh air into the cab with the controls off.
Unfortunately, the air that comes in from the cowl area is also some of the heated air from the engine compartment.
When you put the controls on defrost, you turn on the HVAC system and the problem stops
Why do you never have enough time or money to do the job right the first time, but enough time and money to do it again?
Got all the certifications
25 years ASE Certified Master Technician
GM WCT
Yea..I work at a DEALERSHIP....got a problem with that?
Want to diagnose cars like the Pros? FOR SALE: OTC Perception 2 channel Labscope (badged as a Matco Reality)
This is my personal labscope that I use to diagnose waveforms, like new, comes with leads and training video
PM Me for details
Old 09-21-2004, 12:17 PM
Thank you for the info.. Is there not a way to have it fixed or something so that the defrost does not have to be on all the time? We took the vehicle to a GM Dealership and they said to put the controls on cold and the vent on ground... we did that but it still got to 109F. Should this not be considered a manufacture defect or did we just by a crappy truck?
This is the only real problem we have had with it other then the squeeking in the back which still has to be brought in to be fixed again.
