Go Back   Automotive Forums Car Chat > Toyota > 4Runner/GX470
Old 09-13-2004, 01:34 PM
runnergirl runnergirl is offline
key wont turn at all..??
Help! I have an automatic 95 Runner SR5 4WD, and for two days, I have not been able to turn my key whatsoever! No clicking or anything. Outside lights are working, but no other accesories are. Car is in park. Tried to jump it. ??? Any suggestions/ideas/help would be great!!
Old 09-13-2004, 01:46 PM
Re: key wont turn at all..??
Let me add that I also used my three different keys that I have. And also I had two friends push the car back and forth while i was turning the wheel and jiggling with the key, but to no avail! We did this for quite some time
Old 09-13-2004, 04:04 PM
Brian R.'s Avatar
Brian R. Brian R. is offline
Resident Chemist
Send a message via Yahoo to Brian R.
Probably is the steering wheel locked in a bad position, putting stress on the lock. Might be you need to force the steering wheel more strongly in one direction or the other to get it to turn.
Old 11-04-2004, 11:01 AM
mm5697 mm5697 is offline
Send a message via Yahoo to mm5697
Re: Re: key wont turn at all..??
I am glad to see someone else having this problem. A guy at work is helping me with this. The dash and sterring wheel has been torn out. Trying to get locking pen out. Bought a new ingnition cylinder - that is supposed to be the problem. The key however has to be in accessory mode. So you have to unlock the column. Having serious problems doing this. Any help or a link that can help would be great! HELP!
Old 03-30-2005, 03:11 PM
I just wanted to post an update on my problem. It turned out the key itself just needed replacing. The problem was fixed quickly by simply having a locksmith make a new key for me for $75 or so.
Thanks for the help though. The same key I had used every day just needed to be re-fit to my ignition switch.
Old 03-31-2005, 07:08 PM
BCowley BCowley is offline
Hey glad to hear back in buisness....put 75 seems a little much for a key?
Brian
