Old 09-13-2004, 08:50 AM
the drifter the drifter is offline
Unhappy ford F-150 truck with manual transmission trouble
I have a 2002 F-150 Ford truck with a manual transmission. I try to get it to go into any gear and it won't, I can shut the motor off and then it will go into gear and the truck will then run when I start it back up. When I get on the road it will go into gear and shift most of the time, but it will not go into gear very easily. The clutch seems to have alot of play (not the usual tension). The truck has 45,000 miles on it and I don't think the clutch is bad. Can anybody help me with this problem and how much it would cost to fix it.
Old 09-13-2004, 09:20 AM
crxlvr's Avatar
crxlvr crxlvr is offline
Slowest Automatic Civic
Send a message via AIM to crxlvr
Re: ford F-150 truck with manual transmission trouble
check the throw out bearing.
Stable Of Cars I have Owned:
1991 Honda CRX
1990 Oldsmobile Cutlass Supreme
2003 Honda Accord
1998 Chrysler Concorde
2007 Honda Civic
1997 Toyota Camry
1995 Saturn SC2
1996 Ford Taurus
1991 GMC Sierra
2002 Daewoo Leganza
1999 Dodge Ram
2007 Honda CR-V
2003 BMW 325i
Old 09-13-2004, 09:07 PM
Rufe Rufe is offline
You might of answered your own question without realizing it.
The clutch pedal has too much play in it? Perhaps it is not completely disengaging the clutch plate?
Start here, set the clutch play to specs, first.
If you engage the clutch with the motor off, will the truck roll freely?
