Old 09-12-2004, 11:44 PM
4GZChatch's Avatar
4GZChatch 4GZChatch is offline
Send a message via AIM to 4GZChatch Send a message via MSN to 4GZChatch Send a message via Yahoo to 4GZChatch
VAFC Accuracy
I just got a VAFC, and I was just wondering if anyone knows how accurate the tach on these things is. Does it feed off the distributor wiring, or what? Just wondering if one of you knows....
Remember: You can't spell Crap without APC!
Classic SE-R
GTi-R turbo setup
3" DP
U12 modified ECU
Hyperco GenII suspension
Progress sway
SAFC
etc. etc.
Old 09-13-2004, 12:02 AM
quiXilver's Avatar
quiXilver quiXilver is offline
Send a message via ICQ to quiXilver Send a message via AIM to quiXilver Send a message via Yahoo to quiXilver
Re: VAFC Accuracy
I have a VAFC, it's accurate as hell. Make sure you have the the car type set to "4cyl" and sensor check "IN 6" "OUT 6"
http://www.cardomain.com/quixilver09
B18A
-It's always somethin'
Old 09-13-2004, 01:00 AM
Masta's Avatar
Masta Masta is offline
Send a message via ICQ to Masta Send a message via AIM to Masta
Re: VAFC Accuracy
agreed. it is VERY accurate. i have one myself.
1990 Honda CRX
Next Project: b16a
DREAMWORKS
Cardomain: http://www.cardomain.com/id/importscrx
Old 09-17-2004, 11:34 PM
kris's Avatar
kris kris is offline
Off playing with fire.
Re: VAFC Accuracy
99% accurate. It feeds off your ECU tach signal.
Old 09-18-2004, 03:14 AM
91civicDXdude's Avatar
Re: VAFC Accuracy
they are very accurate. the reason stock tachs are innacurate is becuase they're analog. If the needle gets put on slightly off it will throw everything off, etc.
your stock tach and a VAFC both get their signal from the same place.. negative coil wire, only the VAFC has a digital readout in which the numbers themselves cant change place (like if your needle wasnt on properly etc.)
Old 09-18-2004, 01:24 PM
4GZChatch's Avatar
Re: VAFC Accuracy
Holy cow, a post from Kris!!! Thanks for the input guys!
Classic SE-R
GTi-R turbo setup
3" DP
U12 modified ECU
Progress sway
SAFC
etc. etc.
