Old 09-12-2004, 10:24 PM
Eband00's Avatar
Eband00 Eband00 is offline
Send a message via MSN to Eband00
Viper going bad...
Hey. Several days ago, i wanted to restore my dicast 1:16 dodge viper 96. it was, well, in bad condition. So i sanded the car and started spray painting it. But didn't have enough of it, and th worst thing, is that the paint was from an 88 oldsmobile, so it was out of market, couldn't find the same color...
So i resanded it again, and bought a new red paint... but its is transparent!!!!! it is very thin though.
So i got some questions... i understood i had to apply a primer 1st. i have a grey one. But the thing is, do i have to resand the red "gloss" paint?? cause that would suck.. or can i just apply the primer right away? and it will stick to the red one?
Or if it wont, i dont wanna resand the car a 3rd time, is there a way to remove paint without sanding. some kind of paint removing liquid or smthing like that??
i am a noob, my 1st time doing something with a scale model :-D so dont be too hard on me if i did something wrong... :-D
Old 09-12-2004, 10:25 PM
SupaMan89T's Avatar
SupaMan89T SupaMan89T is offline
Send a message via AIM to SupaMan89T Send a message via MSN to SupaMan89T Send a message via Yahoo to SupaMan89T
Re: Viper going bad...
diecast is down the hall on your right
Project Lexus Revive
Old 09-13-2004, 12:05 AM
DSM-Mark's Avatar
DSM-Mark DSM-Mark is offline
First of all, welcome to AF, and more specifically, the "Car Modeling" section of AF.
What the person above me is trying to say is that for the most part, the "Car Modeling" section of AF mostly deals with plastic, resin, and white metal modeling. It rarely deals with Die Cast as a medium, but some people here will do some of that as well. If you start here http://www.automotiveforums.com/vbul...play.php?f=926 you will find the link to the Die Cast section. It is also very likely that this thread will be moved to that section once a mod sees it.
To answer you question... I'm not an expert, but I think you should be able to paint the primer right over the red spray. However, the more layers you put on, the more paint build up you end up with, and the less detail you end up with. It is normally easiest to go right down to the base medium again, in this case, die cast metal. However, there are better ways to strip the paint than sanding, such as dipping it in Castrol Super Clean, or Easy Off Oven Cleaner, or Brake Fluid, or professional Paint Stripper (careful on this if you have any plastic pieces to strip paint off of). You can read more about stripping paint in the FAQ (see my signature) or by doing a search.
Good luck!
I work slowly!
