Go Back   Automotive Forums Car Chat > Dodge > General Discussion
Old 09-12-2004, 10:21 PM
smarcano smarcano is offline
Question 93 Dodge Shadow Stalling
My car keeps stalling everytime I accelerate and then press on the brake. I have no clue what it could be. I have tried cleaning my choke that didn't work. And nothing else comes to my head so if anyone would know what to do please help me.
Thanks
Old 10-15-2004, 10:32 AM
rwood13 rwood13 is offline
Re: 93 Dodge Shadow Stalling
buy a repair manual, somewhere on the throttle body is a device that controls air into the throttle body, sounds like yours is clogged or stuck, by the way, it does not have a choke
Old 10-15-2004, 12:30 PM
theFREAKnasty82's Avatar
theFREAKnasty82 theFREAKnasty82 is offline
do you have a check engine light on?
Old 10-31-2004, 09:13 AM
mrweiss mrweiss is offline
Thanks
Have your oxygen sensor checked. I had the same problem and after I replaced the oxygen sensor the problem disappeared.
Old 11-01-2004, 01:40 PM
and ???
Old 11-02-2004, 01:31 PM
you might have a weak fuel pump smarcano.
Old 11-02-2004, 01:33 PM
also, when you said it stalls when you accelerate, does it stall right when it accelerates and when you come to a stop or what?
Old 01-04-2005, 11:16 PM
matcee matcee is offline
Send a message via MSN to matcee
have you checked you fault codes'?
try putting in your key, dont turn it all the way on, but until your check oil light comes on, key it this way quickly three times, on the fourth time hold it there and count the blinks. write down the codes,
it should tell you what is wrong. It sounds like it could be your speed distance sensor or oxygen sensor. you need a special tool for the oxygen sensor, looks like a deep socket with a slit up the side for your wires to fit through, cost around $13.00. at kragan or autozone. Id try the fault codes first though.
