Go Back   Automotive Forums .com Car Chat > BMW > 3 Series
Old 09-12-2004, 11:13 PM   #1
Satern
92 325I Tranns Slipping bad
Hey, I have 92 325i with an automatic tranny. The car has 72K original miles. The tranyb started slipping the other day and now it wont move. It sound like a turbine under the car,"the trans". Is this something thats fixable or should I start looking for a new tranny. And by the way, Will an M3 tranny work? Thanks
Satern is offline   Reply With Quote
Old 09-13-2004, 04:26 PM   #2
323imankiks
323imankiks's Avatar
Re: 92 325I Tranns Slipping bad
yes fixable but expensive get some estimates from independent bmw repair shops or transmission shops ..... dont know on a m3 transmission ...
"What happens here stays here" LAS VEGAS
323imankiks is offline   Reply With Quote
Old 09-17-2004, 02:35 PM   #3
hpk
I would highly recommend
that you use only a ZF authorized transmission shop. If you cannot find one, do not let anyone talk you inti rebuilding it. Buy a rebuild from ZF themselves!!!! Check the ZF website.
Good luck and let us know how you make out.
hpk is offline   Reply With Quote
Old 09-17-2004, 02:36 PM   #4
bimmerman333
bimmerman333's Avatar
Re: I would highly recommend
i agree
bimmerman333 is offline   Reply With Quote
Old 09-17-2004, 06:14 PM   #5
jeffreyb4me
Please note thay your 325 doesn't have a ZF unit but a GM trans built in France and the most common failure is the o-rings sealing the front adapter case to the main case. As long as the clutches aren't gone and the lack of 'drive' is caused by very low fluid, any experienced 'Independent BMW' shop should be able to repair it, it's such a common item.
jeffreyb4me is offline   Reply With Quote
