Go Back   Automotive Forums Car Chat > Honda > Let's get Technical!
Let's get Technical! Discussion for hardcore in-depth motor heads!
Old 09-12-2004, 09:50 PM
Jdm_180sx Jdm_180sx is offline
what is needed for ls/vtec?
i own a 90 integra with stock engine and was wondering what i need to do a ls/vtec conversion. i want to do it with a b16 head but can i just swap heads and start driving or do i need any other parts? can i use the stock tranny?
Old 09-13-2004, 06:02 AM
Xesss's Avatar
Xesss Xesss is offline
Re: what is needed for ls/vtec?
i have a 94 ls and i want to do an ls/vtec to my car too. from what i heard or know, u need to a change all these to VTEC, yes VTEC.
1) ecu
2) waterpump
3) timing belt
4) oil pump
other thing u need is a VTEC solenoid and new wiring from the solenoid to the ECU.
yes u can used the stock tranny. if you dont know alot about car, all the thing i listed up above are different in LS and GSR.
hope this help
Old 09-17-2004, 05:44 AM
almxdupintegra almxdupintegra is offline
Headbolts, Power steering bracket, distributor, dowel pins,
theres more to it though cant really remember.
Check out www.importreview.com
FRIENDS DON'T LET FRIENDS DRIVE STOCK
Old 09-18-2004, 03:28 PM
DeleriouS's Avatar
DeleriouS DeleriouS is offline
Send a message via AIM to DeleriouS
i have also heard that you need a new intake manifold (gsr intake)
95' LS Integra
5spd
DC Header (4-2-1)
HKS Super Dragger Exhaust
Skunk2 Short throw shifter
Ground Control Coilovers
Strut Bar
-SOON to be putting in a JDM B16 hydraulic tranny with lightened flywheel and stage III clutch
-SOON to be "home made" turbo charging (goal = 12psi)
-GOAL = 250-300hp with stock internals(probably not reachable)
Old 09-19-2004, 08:28 AM
jojodanca jojodanca is offline
Send a message via AIM to jojodanca
I dont know every thing that needs to be done but I can give everything I know so here it goes. You need to tap and plug the oil supply hole one the bottom left side of the head. 1/8th pipe plug will work for that. Then run an oil supply line from a t-fitting placed on the oil pressure sending unit boss on the block to the vtec oil galley plug on the intake side of the head near the distributer. To make the oil line you need a piece or -4a/n braided steel line about 20" long, with 2 female a/n fittings attached, a 3/8" npt to -4a/n adaptor for the head, a 1/8" npt to -4a/n adaptor and 1/8" npt t-fitting with 2 female sides and 1 male side. you must also open the dowel pin holes one the head to 9/16" because the ls block has larger dowel pins. you should use a ls head gasket. also a ecu from a vtec ecu for your year and model. you have to run jumper wires for the 90 u run 1 from the a-8 pin in the ecu to the vtec silenoid 1 from the b-5 pin to vtec pressure and 1 from the b-19 pin to the knock senser the you will have to hookup by simply groundin it to the chassis the is hooked up to the ecu on any year vehical and for the 94 you will have to run jumper wires but the pins are different the vtec silenoid wire goes from the a-4 pin to the silenoid a wire from the d-6 pin to the vtec pressure and a wire from the d-3 pin to the knock sensor that you can hookup the same way as the 90 just ground it to the chassis that the ecu is hooked to or get a hasport ecu for vtec with no knocksensor and thats all i know about the swap so i hope it is helpful to you let me know if it is
Old 09-19-2004, 12:47 PM
mellowboy's Avatar
mellowboy mellowboy is offline
Amy dragged me here...
Send a message via Skype™ to mellowboy
yeh just go to importview.com. These guys definitely know what they're doin. I dunno why they pick a gsr head over the b16a. Thats just something i dont agree on. Then again that research is pretty old so maybe they have different ideas now.
