Go Back   Automotive Forums Car Chat > Ford > Thunderbird
Old 09-12-2004, 08:35 PM
lightin rod lightin rod is offline
Send a message via MSN to lightin rod
bad hesitation
i have 94 thunderbird LX with the 4.6L and when the engine is cold and i step on the gas it goes up to 2 grand and starts popping and banging and after it idles for a few minutes i can wind it up all the way if i barely step on the gas but if i step on it it falls on its face popin and banging and if its sat for a couple days it cranks longer on the first start up i tried to pull the codes and there are none present. So I am wondering if its a throttle position sensor of fuel pressure regulator. everybody i talked to said the engine coolant temp. sensor was so i replaced that and it helped some but it still pops and bangs. i just bought this car 6 monthes ago and i am going nuts from all the problems i havin with it any help is apreciated greatly
Old 09-12-2004, 10:37 PM
emailer33 emailer33 is offline
Send a message via AIM to emailer33
Re: bad hesitation
engine timing possibly? i mean the advance could be off and is why the fast gas knocks it off?
Old 09-12-2004, 11:02 PM
Re: bad hesitation
ok i have no idea how to tell if its off or adjust the timing on it because its distributerless
Old 09-13-2004, 01:05 AM
Re: bad hesitation
oh, should've done my research, nvm then, the timing is computer-controlled.
Old 09-13-2004, 08:41 AM
Re: bad hesitation
oh thanks anyway emailer33 atleast it was an idea
Old 09-14-2004, 11:10 AM
thunderbird muscle's Avatar
thunderbird muscle thunderbird muscle is offline
Re: bad hesitation
Could it possibly be your cats? Sounds like some of the symptoms to me.
A founding member of HNF car club!
Do you know what it feels like to do an amazing burnout listening to that wonderful exhaust note, Oh you drive a honda sorry dude, but theres hope they still make nitrous oxide!
Racing a Honda is like being in the special olympics even if you win your still retarded!
Old 09-14-2004, 01:06 PM
Figori's Avatar
Figori Figori is offline
Send a message via Yahoo to Figori
Re: bad hesitation
O2 sensor(s)?? That could cause the incorrect mixture.
"Short, sweet, and to the point"
1987 CRX Si - Project Si 'RexSi'
1996 Ford Thunderbird 4.6L V8 - Plastic Intake Manifold, FTL.
2004 Nissan Sentra, 1.8s - The "s" stands for smooth....... ?
Old 09-14-2004, 06:31 PM
Re: bad hesitation
ok thanks guys ill look into those ideas. could it be a contaminaterd maf sensor because it had a kn and in and the morons i bought it from took it out and replaced with a regular filter then sprayed carb cleaner into the intake hose in attemp clean it. at one time it had lean mixture trouble codes in the computer. any thoughts?
Old 09-14-2004, 07:28 PM
Re: bad hesitation
Yes it could be the maf! Mine did similar due to the maf. Though without the popping.
Old 09-14-2004, 07:50 PM
Re: bad hesitation
well i cleaned the maf with some electrical contact cleaner the wires were black and had a gummy film on them it took alot of cleaner but got it all shiny again it acts like a whole different car FINNALY things are working right. Thanks alot to everyone that posted
Old 09-28-2004, 05:25 PM
wulleymammoth wulleymammoth is offline
Talking You helped another Tbird owner! THX
Just wanted to thank everyone, who kicked in their ideas, on this thread. You fixed my Tbird too! Thanks! My car was doing pretty much the same thing, and was also throwing "lean codes", for bank1, and bank2. I took out the MAF, and cleaned it with a soft-bristle tooth brush. It took about five minutes, and my car was running like new again :o). My "next stop", was to replace the catalytics, which I wasn't too thrilled about. Thanks again!
Best regards,
wulleymammoth
