Old 09-12-2004, 01:18 PM
visonofdisorder visonofdisorder is offline
Unhappy standard to zc?
hello, i have a 89 civic standard, with the 4 speed and everything, i was wanting to do a zc motor swap, i was planning on ordering the zc with 5 speed and ecu combo from nippon but i was wondering is it as easy to switch to zc as it is with a dx? and what about 4 speed to 5 speed? please help me thank you
Old 09-12-2004, 04:46 PM
mellowboy's Avatar
mellowboy mellowboy is offline
Amy dragged me here...
Send a message via Skype™ to mellowboy
Re: standard to zc?
Its an easy swap. The only thing is that you have to convert dpfi to mpfi. Search it...you'll see alot of ppl asked this question
Old 09-12-2004, 04:55 PM
Posey88cvic4dr's Avatar
Posey88cvic4dr Posey88cvic4dr is offline
Send a message via AIM to Posey88cvic4dr
Re: standard to zc?
when you order the swap, it comes with the MPFI. the only other thing you need is a resistor box. You can get one from a Si CRX, its a little silver box about 2 inches long that's in the very top right of the engine bay.
4g4d4Life <--Link To My Car
TEAM CHOZEN
Old 09-12-2004, 06:18 PM
91civichatch2571's Avatar
91civichatch2571 91civichatch2571 is offline
Send a message via AIM to 91civichatch2571
And since you have an STD lol, your going to need to get new hubs and axles. You'll need to upgrade to DX/Si hubs and halfshafts.
ZC stuff
http://dh-racing.com
http://www.thezcr.com/html/zcbook.php
http://dmoore.com/crx/zc.htm
http://www.jgenginedynamics.com/HOME%20PAGE
http://www.theoldone.com/
Old 09-12-2004, 08:01 PM
mellowboy's Avatar
Re: Re: standard to zc?
He still needs to get it converted.
Old 09-12-2004, 09:43 PM
91civicDXdude's Avatar
Re: standard to zc?
If you have the choice, order your ZC with an Si transmission and then you can use your stock axles and hub assembly. If you get the ZC, you'll need 90-91 integra axles, and knuckles from an 88-91 DX/LX/EX/Si or 90-93 non ABS integra knuckles. with the 90-91 EX or 90-93 teg spindles, you'll also need atleast a 14" steel wheel since 13" wheels and the 14" alloy wheels from Si models will not clear the larger brake setup.
