Go Back   Automotive Forums Car Chat > Mercury > Villager
Old 09-12-2004, 09:31 AM
bennyk bennyk is offline
97 Villager/ Quest Headlight problem
The right hand headlamp doesn`t work...no power at light wiring...swapped relays with left side..still no go...also dash high beam indicator always on Hi...the single headlamp still switches to high beam...I suspect the hi beam switch in the stalk...any other ideas???..thanks, Benny
Old 11-26-2004, 12:15 AM
jimoney jimoney is offline
Re: 97 Villager/ Quest Headlight problem
Benny,
I know exactly what is wrong with your villager! Why? Cause the exact same thing happened to mine. It drove me nuts. Until finally I had had enough and took it to a automotive electrical specialist. After one hundred dollars I had my answer. The problem lies in the Daytime running light module. (engine compartment, left side near firewall) Mine had a loose solder connection on the circuit board. I simply "floated" all the solder connections on the board and bada bing it was fixed.
Jimoney
