Old 09-11-2004, 11:06 PM
5thGenAccord's Avatar
5thGenAccord 5thGenAccord is offline
Send a message via AIM to 5thGenAccord
Question Question for Anyone!!!!
WOuld anyone happen to know how much voltage the light in a 97 honda accord pulls?
How could i run a power supply from the interior fuse box? has anyone done that?
hope you guys can answer my questions
Old 09-11-2004, 11:17 PM
phoenixitc phoenixitc is offline
Re: Question for Anyone!!!!
Which light?
Old 09-12-2004, 09:25 AM
Mr. Anderson's Avatar
Mr. Anderson Mr. Anderson is offline
It could be just me.......but what the heck is this guy talking about!?!?!
[img]
Old 09-12-2004, 09:05 PM
opz...im sorry fellaz. i guess i was too tired to notice that i left out a minor detail .
the light i was talking about is located on top of the pullout ashtray. in mine its a small blue bulb the illuminates my coins that i keep in there.
please excuse me for the confusion.
Old 09-13-2004, 05:52 AM
Aw man! I used that for power source when I had an airbag defeat switch installed. Can't remember...
Old 09-13-2004, 02:16 PM
it wouldnt happen to be about 7.5 volts? it may be a farfetched guess but its a guess none the less. can anyone make my assumption valid?
Old 09-13-2004, 04:07 PM
mpumas mpumas is offline
It is probably a 12v bulb, the same voltage as the battery. It may be reduced by the dashboard dimmer knob.
Old 09-13-2004, 06:43 PM
AccordCodger AccordCodger is offline
It'll be 12v. But you'd have to check the fuses and/or wiring diagram to find out how much current the circuit is intended to supply (and DON'T put a bigger fuse in -- the wiring may not be able to handle it, and you'll have a big electrical mess, or, worse, a fire).
The best auxiliary power souce is the cig lighter. The newer cars don't even have a cig lighter - they just plug the socket with plastic and call it a power outlet!
Old 09-13-2004, 09:01 PM
one more question. if i were to wire it to an electronic device that requires only 7.5 volts, would any complication occur? (i.e. putting to much power to the device and probably messing it up)
would i bebale to place a smaller fuse on there?
Old 09-14-2004, 12:43 PM
Yes - you'd mess it up. Fuses do not control voltage, they control amperage. If you have a device that needs 7.5v, then I suggest you go to Radio Shack, explain the situation, and they will probably be able to sell you a voltage converter (I have one that supplies 3v, 6v, 7.v or 9v when plugged into the cig lighter). Take the device in with you if possible.
Old 09-15-2004, 07:53 PM
scubawrstlr's Avatar
scubawrstlr scubawrstlr is offline
Send a message via AIM to scubawrstlr Send a message via MSN to scubawrstlr Send a message via Yahoo to scubawrstlr
yes, radioshack will hook you up.
I've only just begun...
Old 09-15-2004, 08:20 PM
ec437's Avatar
ec437 ec437 is offline
yeah, I think that you don't know the difference between voltage and watts.
SoStAsSaId: and the flight attendant is cute... if i was a lesbian, i'd join the mile high club
<---call this number
Old 09-15-2004, 08:49 PM
Easy, ec437. Not everyone aced Physics. Some of us are electricians, some aren't.
Old 09-17-2004, 09:35 AM
ok thanks accordcodger, mpumas, phoenixitc. i am going to radio shack today to buy that converter.
