Old 09-11-2004, 07:58 PM
brenscars brenscars is offline
87 CRX HF won't idle
I've got an 87 CRX HF that will run fine with your foot on the gas. Carburetor is newly rebuilt, flange at base of carb is new, new fuel filters, new plugs, valves adjusted, fresh gas. Car will run fine if gas is poured directly into carb. Could the screen in the tank be clogged? This is the only thing I have not checked. I am at a dead end!
Old 09-11-2004, 10:14 PM
93_R/T_TT_Stealth's Avatar
93_R/T_TT_Stealth 93_R/T_TT_Stealth is offline
Send a message via AIM to 93_R/T_TT_Stealth Send a message via MSN to 93_R/T_TT_Stealth Send a message via Yahoo to 93_R/T_TT_Stealth
Re: 87 CRX HF won't idle
sounds like your not gettin an efficent amount of fuel to the carb. is the gas pump the orig? the pump my be starting on its way out an not workin properly.
Old 09-11-2004, 11:10 PM
Cjz89civic's Avatar
Cjz89civic Cjz89civic is offline
AF Premium User
Send a message via AIM to Cjz89civic Send a message via Yahoo to Cjz89civic
Check in the other forums for your car they would be able to help you more than us
http://www.automotiveforums.com/vbul...play.php?f=677
Mods: D16Z6 Turbo'd P28 ecu and Greddy emanage for fuel. FWD tire smoker
My first Civic love Died from 92 year old Fart not watchin out.
Old 09-11-2004, 11:12 PM
ZCCivicBoy ZCCivicBoy is offline
Banned
Send a message via AIM to ZCCivicBoy
aye try an check the fuel pump or take the fuel line off the carb and turn the key on and see if gas come out the line..
Old 09-11-2004, 11:15 PM
Figori's Avatar
Figori Figori is offline
Send a message via Yahoo to Figori
Re: Re: 87 CRX HF won't idle
In that forum, it could take days to get an answer.
Check your fuel filter, and if all else fails, your pump.
"Short, sweet, and to the point"
1987 CRX Si - Project Si 'RexSi'
1996 Ford Thunderbird 4.6L V8 - Plastic Intake Manifold, FTL.
2004 Nissan Sentra, 1.8s - The "s" stands for smooth....... ?
Old 09-11-2004, 11:18 PM
Cjz89civic's Avatar
AF Premium User
well all of us here should have the basics of car knowledge but when you say carb most of us here dont have any carbs on are car its either DPFI or MPFI with the exeption of a few of our EURO friends. But its not a 4th gen car.
Old 09-11-2004, 11:19 PM
Figori's Avatar
I understand. He's just trying to find the best way to get any answer. Not so much an educated one.
Old 09-11-2004, 11:29 PM
electronic injection of carb doesnt matter - just check the pump like i said if its not working properly you know if you do what civicboy an i said -if it shoots out then you good on the pump - then you may have a v line problem....
