Old 09-11-2004, 06:56 PM
Nuttybabs Nuttybabs is offline
Vibration/Shaking
I just love these forums--so glad I have found one for my car.
I have a 91 Grand Am, 80K miles. I love this car, but if I can't find the fix for it my husband says it goes to the trash. When idling my car shakes--I don't mean just a little vibration either--it shakes and has died a couple of times. If I put the car into N or P it stops shaking, only happens when in gear. Does not make any difference if A/C is on or off. Have changed the engine mounts, had the tranny checked. I need some suggestions on where else to look. I love my car and do not want to get rid of it. Thanks in advance for any advice given. Nuts
Old 09-18-2004, 11:58 PM
Tattoo1981 Tattoo1981 is offline
Re: Vibration/Shaking
My girlfriend had a similar problem with her 2000. I changed the fuel filter and so far it has seemed to stop. She had other problems with it stalling but it would shake as you mentioned and that too went away. Good luck hope it works for you too.
Old 09-19-2004, 07:40 PM
bcopeland bcopeland is offline
Seems like you need either motor mounts or your throttle body needs cleaning.
Old 09-19-2004, 08:12 PM
grfnkl's Avatar
grfnkl grfnkl is offline
Send a message via AIM to grfnkl
I would have your fuel system checked, Fuel pump, fuel injector fuel filter and definetly have the throttle body cleaned, also check your air filter if it hasn't been replaced recently it could cause the same thing...
