Transmission Fluid Dipstick?
I haven't taken the time to look thoroughly, but is there a dipstick to check the transmission fluid level, if not, how do i check the level when i change it and what not. Also what fluid is reccommended. (93 stealth es 5 speed)
Re: Transmission Fluid Dipstick?
no manual trans have a dipstick. you have to jack the car up, make sure its level and pull out the fill plug. it should be right at the level of the hole, if it comes out, let it come out until it stops. if it doesnt come out see if its lower than the hole by putting your finger in there, and if so add some.
thanks a lot, wouldn't of known that.
http://www.stealth316.com/2-awddrainfill.htm
This should help with locating all the drain and fill plugs, and answer any questions about which fluids to use
96 3000gt vr4 -K&N FIPK -Proboost mbc -Cusco front + rear strut bars -Greddy type-s -ATR downpipe -no cats -15Gs, 3sx aluminum pulley, FMIC, SAFC, walboro pump, EVO 560ccs, and Meth Injection Kit all waiting to go in shortly. Your 1996 Mitsubishi 3000GT VR-4 is the 92nd out of the 315 that were made that year. Only 21 of which are exactly identical. |
