Old 09-11-2004, 01:16 PM
Chattel Chattel is offline
'93 Z28 fan problems
Hi guys, I'm a noob around here, so first things first Hi =)
Now my problem:
I have a 93 z28 Camero. Neither of the fans are working, obviously causing it to overheat. The problem is we can't find out what is wrong with them. I've checked the 2 relays (I'll ask about the 3rd in a minute), they are fine, and it has brand new motors. I haven't checked the 3rd relay, because I'm not sure where it is, can anyone tell me? The guy helping me out with my car thinks that's the most likely culpret, but he doesn't know where it is either, and I'm having a hell of a time finding out on the internet.
Also, is it possible that this could be a thermostat problem? Or perhaps even a wiring problem somewhere? The primary fan has never worked since I've owned the car, but the secondary one worked until recently.
Any help would be great.
Old 09-11-2004, 03:02 PM
twdz28 twdz28 is offline
Re: '93 Z28 fan problems
Cooling Fans Schematic
http://shbox.com/1/fan_schematic_1995.jpg
Manual Fan Switch Connection Location
http://shbox.com/1/fan_switch_wires.jpg
Manual Fan Switch Diagram OBD-I
http://shbox.com/1/fan_sw_diagram1.jpg
95 Z28 Black on Black on Black. Mods: 355CI and lots more...
Originally Posted by Mordant
I'd say if they ask about material possessions then it's fair game to ask them what kind of underwear they wear, may as well get both sides expectations on the table as soon as possible.
Old 09-12-2004, 11:15 PM
Chevyracincamaro's Avatar
Chevyracincamaro Chevyracincamaro is offline
do the fans come on when you turn on the a/c? does the car overheat when you are moving? if not than the problem is not your thermostat, if so than you might want to check that also. otherwise, i would look into all the relays and the coolant temp sensors to see if they are functional...
*Better power-to-weight ratio than a C6 corvette*
