Go Back   Automotive Forums Car Chat > Engineering/ Technical > Forced Induction
Forced Induction Discuss topics relating to turbochargers, superchargers, and nitrous oxide systems.
Old 09-11-2004, 12:08 PM
tmramsburg tmramsburg is offline
Send a message via AIM to tmramsburg
need help fast plz!!!!!
if an fmu is set up with a diaphram for 30lb injectors, what ratio is that?
thank you!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Old 09-12-2004, 02:37 PM
KC Ron Carter KC Ron Carter is offline
hmmm,
I am guessing this is a real question.
I can only assume the issue is what percentage of maximum flow you will have after installing a larger injector, 30 lb.
Here is a link to show some flow ratios on Bosch systems.
http://www.bsmotor.com/cgi-bin/bsmot...&ant=6&pros=65
Note the percentage varies with the pressure of the fuel.
Later,
