Old 09-11-2004, 11:54 AM
ben361 ben361 is offline
Send a message via MSN to ben361
04 s-10 factory fog lights
I have an 04 s-10 4X4 and I have installed the factory fog lights and the factory switch in the dash. It appears the the switch olny sends a short signal to the bcm which turns the fog light relay on. Dose anyone know how to program the bcm so that the fog lights work.
Old 09-11-2004, 05:08 PM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Re: 04 s-10 factory fog lights
Is the relay there for the fog lights?
Old 09-11-2004, 06:58 PM
yes, the relay is there, The switch on the dash sends a ground to the bcm. The bcm grounds the relay to switch on the fog lights. I have tested all the wires and it stops at the bcm.
Old 09-11-2004, 07:33 PM
BlazerLT's Avatar
AF -Advisor
new relay needed?
Bad ground?
Wired Properly?
Old 09-13-2004, 09:14 PM
All the wires were pre wired in the truck from the facory, I did test all of them and all good. The relay was replaced with the horn relay and, same result, horn still works, so not relay problem. I connection stops at the bcm. Why would fog lights go through the bcm???
