Old 09-11-2004, 11:49 AM
Brian51 Brian51 is offline
Antenna motor
The antenna motor on my 92 Jeep Cherokee continues to run with the antenna not moving. The gears must be shot in the motor, how can I remove the antenna and motor? Is access only through the dash as I cannot see any external access.
Old 09-11-2004, 04:04 PM
JDPascal JDPascal is offline
Re: Antenna motor
You access the antenna by removing the inner fender.
There are a couple of bolts under there and you have to remove the mast and a nut on top of the fender.
for the power antenna, disconnect the negative cable from the battery for a precaution and then take out the kick panel on the passenger side.
There is a relay and other wiring that you disconnect in there.
JD
Old 09-12-2004, 09:26 AM
Re: Antenna motor
Thanks JD. Bit of a novice mechanic here. How do I access the inner fender is that through the engine compartment under the hood?
Old 09-12-2004, 10:12 AM
Re: Antenna motor
It is inside the wheel well
