Go Back   Automotive Forums Car Chat > Lincoln > Town Car
Old 09-11-2004, 10:00 AM
gluver2002 gluver2002 is offline
95 TC headlights
My 95 town cars lights don't work and I need help trying to troubleshoot prob. The switch won't turn em on automatically or manually. If I push the brights turn signal switch they don't work either. Brights only work if I pull and hold signal arm. Any suggestions
Old 09-14-2004, 03:15 PM
ltdltc ltdltc is offline
You push the turn signal stalk forward for the brights right?
If you have and they still don't work then you may have a faulty MFTSS (multi-function turn signal switch). You may need to replace it, sometimes the contacts can corrode and it malfunctions.
Although you may want to make sure that the filaments on the headlamps themselves aren't burnt out, the headlamps have dual filaments (if your stalk does go forward) for each the low and high beam.
Richard
1995 Lincoln Town Car Signature Series
Past
1992 Lincoln Town Car Cartier Designer Series
1992 Lincoln Town Car Executive Series
1990 Lincoln Town Car
Old 09-14-2004, 07:46 PM
Re: 95 TC headlights
richard.. My headlights sometimes come on if I jiggle the turn signal but most time they just stay off. So I know my lamps work. It sounds like it may be the mftss. Is it hard to replace it? Thanks for the info. JS
Old 09-14-2004, 10:38 PM
Well as you can imagine you have to take the steering column cover off, then it's just a matter of unplugging wires and removing screws.
You might be able find used at an auto recycler but unfortunately it is a Ford only part if you want it new.....
Good luck
Richard
Past
Old 01-20-2008, 04:06 PM
cmowat401 cmowat401 is offline
I have the same car and the same problem...Started this morning after a cold snap.....Battery was dead to....Had battery Checked and is fine....Only the running lights and high beam work
