Old 09-11-2004, 01:56 AM
kingwillz kingwillz is offline
Send a message via AIM to kingwillz
One Wiper Conversion On 4th Gen Accord
Wats Up!!!
I Just Want To Know One Thing. Can Somebody
That Has Done This To Their Car Please Tell Me How To
Do The One Wiper Conversion (european Look)....
I've Seen It On A Couple Other Hondas And I Want
To See How It Looks On Mines. If I Like It, I'll Keep It For A While
And If It Sucks, Its Commin Right Off. So Yea, Can Somebody
Tell Me Wat I Have To Do, Like Step By Step.
By The Way I Drive A 1992 Lx
Thanks For Ur Replies
-1-
Old 09-13-2004, 08:25 AM
94accordVTEC 94accordVTEC is offline
Send a message via AIM to 94accordVTEC
I have a 5th gen but it should be the same.
1. remove both wiper arms...open the hood and the nuts are right at the bottom of the arms
2. take the drivers side wiper arm and install the passenger side wiper blade on it...as the passenger side blade is longer.
3. install the drivers side arm on the passenger side...where the blade slides on is geared such that you don't have to put the wiper in the park position you can position it at any height on the windshield that you want.
4. it takes a minute to find the correct position for maximum windshield coverage without having the wiper go off the side of the windshield on either side.
5. buy some RAINX and use it...you'll understand what i mean the first time you drive in the rain and you can't see because of the parts of the windshield that isn't covered by the wiper.
Old 09-13-2004, 05:53 PM
Re: One Wiper Conversion On 4th Gen Accord
woah thanks alot man....it only took me like 10 mins. max to do it, i thought it was going to be much more complicated...also, damn, its goin to take a while for me to get used to this look, i mean i want to be unique wit this style, i've seen alot in NY but not down here in Jersey.
anyways thanks for ur help and good luck.
Old 10-19-2004, 01:11 AM
henrymv henrymv is offline
Dude....so I get this right....i am just swapping blades arms? Can this been done on a 4th generation accord???Aren't 4th generation drivers wipers longer than passenger?
Old 10-19-2004, 01:31 PM
Re: Re: One Wiper Conversion On 4th Gen Accord
Dude...yeah...use whichever blade you want, i used the longer one and moved the drivers side wiper arm to the passenger side mount as i have said above but it really doesn't matter, just use the one that gives you the most coverage. Even if you try every combination your still only looking at 30 min worth of work.
Old 10-19-2004, 01:32 PM
and just for the record henrymv...kingwillz has a 4thgen and it worked on his as i described so i guess it can be done on a 4thgen
Old 10-19-2004, 05:24 PM
ok...well i will give it a try....
Old 10-20-2004, 07:24 AM
scubawrstlr's Avatar
scubawrstlr scubawrstlr is offline
Send a message via AIM to scubawrstlr Send a message via MSN to scubawrstlr Send a message via Yahoo to scubawrstlr
I've only just begun...
