Old 09-10-2004, 10:50 PM
ef four door's Avatar
ef four door ef four door is offline
Question mpfi wiring?
hey i am about to do a mpfi swap on my 89 lx 4-door. i have tried to do a mpfi swap before, but it didnt work for some reason (i think it was the wiring). on the cylinder position sensor, youre supposed to use shielded wire. i did this on my last swap but i used 22 gauge wire with, like, four different strands of wire inside. this time i am thinking of pulling some wire out of a junked car with the pins still intact. my question is, if you have done a mpfi swap on your car, did u use shielded wiring for the cps? if so, what kind? another question: for pulling pins on the ecu plugs, what would work good without having to order a honda pin pulling tool?
1989 civic lx four door, MPFI SOHC ZC powered, SOLD
1988 civic dx four door, D15B VTEC...permanently converted to obd1
Old 09-10-2004, 11:08 PM
EF You's Avatar
EF You EF You is offline
EF Life Giver
Send a message via AIM to EF You
Re: mpfi wiring?
i used a really small allen wrench to remove pins, always worked well for me. i used a piece of shielded wire from a junk harness i had lying around.
over 10 grand in parts, and about 300 hours of labor, and i only spent 3k. and then Katrina filled it with mud.
Old 09-11-2004, 12:29 AM
civickiller civickiller is offline
Send a message via AIM to civickiller
i didnt use shielded wire when i did my mpfi, the motor started fine, never got to drive it on the street so yeah.
i used a small glasses screwdriver to depin my ecu pins
Team Lonely Drivers
Old 09-12-2004, 08:25 AM
4GZChatch's Avatar
4GZChatch 4GZChatch is offline
Send a message via AIM to 4GZChatch Send a message via MSN to 4GZChatch Send a message via Yahoo to 4GZChatch
Re: mpfi wiring?
I bought a set of jewelers screwdrivers at the grocery store, which had a tiny screwdriver perfect for ecu pins. also, I have done two mpfi swaps without ever using shielded wire and never had the first problem due to it. I've never gotten codes or anything.
Remember: You can't spell Crap without APC!
Classic SE-R
GTi-R turbo setup
3" DP
U12 modified ECU
Hyperco GenII suspension
Progress sway
SAFC
etc. etc.
