Go Back   Automotive Forums Car Chat > Nissan > Frontier | Navara
Old 09-10-2004, 04:58 PM
jlimrick jlimrick is offline
Unhappy 1998 Frontier misfire--please help
I have a 98 Frontier 2.4L. It has a code P0302 for misfire on cylinder 2. I've changed the plugs, cap, rotar and wires. It only misses under a light load when driving. If you put full throttle it doesn't miss and at idle it doesn't miss. It only misses when starting out or when maintaining your speed, but as soon as you put on more throttle it doesn't miss. I was thinking that it could be an injector problem. I switched 2 of the injectors to see if the misfire went to a different cylinder and it didn't. PLease someone help.....
Thanks,
JL
Old 09-20-2004, 05:48 PM
vdubdoctor vdubdoctor is offline
will give you all the info I have............
I had the same problem and finaly took it the the dealer.
They replaced the injector, and the EGR valve because it was
stuck open with carbon build up. They replaced the injector because it was "suspect" but I think it was the EGR causing it all and they just mis-diagnosed it and made me pay for it!!!!!!!!!! however, I got a new intake manifold gasket and labor out of the deal for free 'cause they
mis diagnosed it as that first and replaced it with no change in the way it ran.
Hope this helps!
Old 09-27-2004, 10:09 PM
sidzorn's Avatar
sidzorn sidzorn is offline
Send a message via AIM to sidzorn Send a message via Yahoo to sidzorn
Re: 1998 Frontier misfire--please help
take carb cleaner and spray it where the head and intake meet the intake gaskets leak
96 gt bbk x-pipe lakewood traction bars american thunder cat back march ram air k&n richmond gears
97 maxima in progress
Old 10-04-2004, 03:03 PM
Re: will give you all the info I have............
Hope this helps!
Thanks. I'll check that out.
Old 10-04-2004, 03:04 PM
Re: Re: 1998 Frontier misfire--please help
Thanks. I'll give this a try. Hopefully that's all it is.
Old 10-25-2004, 11:11 AM
Exclamation Re: Re: Re: 1998 Frontier misfire--please help
I tried this and there was no change in the idle or miss at all.
I find it strange that it doesn't miss when the engine is cold. It only misses on cylinder 2 after the engine has warmed up. I've already checked the vacuum lines and they're fine too.
Old 04-11-2005, 07:18 PM
dnanorton dnanorton is offline
I have a cyl 2 misfire on my 98 frontier 4x4 also. I have only about 75 psi of compression in cyl 2 and 140 on the other 3. The local shop wants to rebuild the head and do a valve job.
What is your compression and have you found anything else out about your cyl 2 misfire?
