Go Back   Automotive Forums Car Chat > BMW > 5 Series
Old 09-10-2004, 02:14 PM
nowhere man's Avatar
nowhere man nowhere man is offline
Dash "gear" lights out of sync i.e. P R N D 1 2 3
My '88 528e automatic has a prob with the dash lights displaying which gear its in (P, R, N, D, 1, 2, 3). "Park" lights up fine, but when i put it in "drive" either no light shows or the "neutral" light comes on in which case i have to tap the shifter in order to get it out of "neutral". Maybe something needs to be re-adjusted dealing with my shifter???
Thanks for any help
Old 09-10-2004, 04:21 PM
323imankiks's Avatar
323imankiks 323imankiks is offline
not sure if the same but i had the same problem in my 323i the display was broken i would put in drive but it would say i was in reverse i replaced my shifter display and all is fine now. mine was on the floor console if its in your dash cluster not sure
"What happens here stays here" LAS VEGAS
Old 09-10-2004, 05:20 PM
Re: Dash
Thanks 323... My display IS in the dash so Im going to have a look see when I replace nicad batteries to instrument panel. By the way, did you buy the "shifter display" new or, get a used one? Either way, how much did it cost???
Thanks again
Old 09-12-2004, 01:05 AM
jeffreyb4me jeffreyb4me is offline
Re: Dash "gear" lights out of sync i.e. P R N D 1 2 3
The 'D' lamp in the cluster, being the most used, burns out. you can replace the light bar in the cluster OR if you have the time solder in a replacement bulb. Not much adjustment at the lever for your other complaint, the switches wear.
