Go Back   Automotive Forums Car Chat > Dodge > Daytona
Old 09-10-2004, 12:18 PM
SVTcobra306's Avatar
SVTcobra306 SVTcobra306 is offline
New Forum??
OK I either haven't been paying attention, or this forum is new in the last couple of weeks...
Admin-is this for 80's/early 90's K-car based G-bodies, or is it meant for the old Charger Daytona's??
If it's G-bodies, then Cool...forums for us are few and far between.
1994 SVT Cobra. 306, Ported GT-40X's, Crane 2031, NX Wet Kit (100 shot for now),TKO 500, TwEECer R/T, and all the bolt-ons.....
http://www.cardomain.com/id/mccobra94
1995 F-150 SC/4X4 351W/E4OD, K&N, Custom Exhaust w/Flowmaster.
Freedom Isn't Free.
Old 09-10-2004, 12:36 PM
Re: New Forum??
OK just saw the LeBaron forum under Chrysler, so I'm assuming it's for G-bodies...
Roll call, 'Tona drivers! I'll start:
1989 C/S Daytona, 2.5 Turbo I/A413 auto trans. I have added:
T-II I/C setup
Talon BOV
S-60 turbo
FWD-P 15 PSI computer cal
Grainger Valve
MP +20 injectors
Accufab AFPR
Custom 2.5" full exhaust, NO TIP! Exit is invisible behind the bumper...
ported exhaust manifold
KYB GR-2 Shocks/struts.
I am very soon going to get a RRR and go for 18 PSI!
Hopin' for 13 second timeslips @18 PSI...
Freedom Isn't Free.
Old 09-18-2004, 12:41 AM
TheKhaos's Avatar
TheKhaos TheKhaos is offline
I'm driving a '93 ES with the 3.0L and automatic tranny. I've installed a 52mm throttle body.
Yup.
Old 10-08-2004, 03:46 PM
diabloed's Avatar
diabloed diabloed is offline
Re: New Forum??
89 ES 2.5 N/A swapped to 89 Maseratti TC 2.2 TII
5-Speed A-520
TurboXS RFL BOV
FWD-P Stage 5 22 PSI computer cal
MSD 3-Bar map
Grainger Valve
MP +40 injectors
Accufab AFPR
Walbro 255 l/hr fuel pump
Custom 3" exhaust
Eibach Springs
McLeod RevLok clutch
Quickor solid bobble strut
Adjustable cam sprocket
Underdrive pully
Chrome Moly Transplate from FWD-P
Magnecor 8.5mm Wires
MP valve springs
High RPM lifters
K&N drop in filter
Falken Azenis Sports
Melling high-volume oil pump
Gutted interior
a slew of Atometer UltraLites
soon to rebuild with forged wiseco and all ARP hardware.
i think that's it....
Old 10-08-2004, 08:55 PM
AWP9521 AWP9521 is offline
Re: New Forum??
1989 Daytona Shelby, 2.5 TI, Silver with burgundy interior. I own it but my son drives and pays for it.
ARP Head Studs
MP Camshaft (lift and Duration unknown at the moment)
Stock Pistons, Rods, Crank
Balance Shafts Removed.
Stock timing gears,
Swapped out the A 413 for an A 555 5-Speed (After burning up 2 of the 413's)
Stock Turbo 13 PSI (Plan on a S-60 soon)
Stock BOV
S-60 Computer
Stock Injectors (Have larger MP units but will not go on til the Turbo Change)
T II Intercooler/Radiator setup (Added after the 413 Tranny went bye-bye)
Stock Fuel Pump (Will go higher rate pump after Turbo Change)
3" Exhaust System
Old 10-12-2004, 10:22 AM
Re: New Forum??
Hey diabloed, we run into each other often! (I'm AJMcCurdy on TD.com...)....
Freedom Isn't Free.
Old 10-12-2004, 12:53 PM
diabloed's Avatar
Re: New Forum??
I thought that was you! howdy sir!
Old 10-19-2004, 08:36 AM
PWMAN's Avatar
PWMAN PWMAN is offline
Re: New Forum??
Yeah I haven't been on automotive forums for awhile, the daytona section is new. I remember suggesting one though!
Look at my sig-
Things I couldn't fit-
TurboXS type H BOV
88' roller cam
engine is 87' T2 crossdirlled with new STD bore cast mahle's, T2 rods and T1 cast crank
Mopar front motor mount, MP bobble strut, MP tranny mount, custom poly side motor mount.
Who else is from TD.com? I am MOPARZRULE on that forum!
Anybody else have dyno's? The IC is the BEST mod hands down, exhaust being the second best. Well the custom cal for 22 PSI don't hurt either...LOL.
88' Dodge Shadow- 2.2L, 5 speed...a couple mods
[email protected] MPH
