Old 09-10-2004, 11:52 AM
ktnguyen71 ktnguyen71 is offline
No light at air flow knob
Hi,
Do you why the light went out at the air flow control know, hot/cold knob and the rear defroster button? The light/fuse is out? How to fix it?
THanks,
ktnguyen71
Old 09-10-2004, 01:15 PM
94hondaacc 94hondaacc is offline
check if the dashboard lights are out, if not then its not the fuse. they use small bulbs, which you probably got to get from the dealer. i had the same problem and it was the bulbs. they are really little and kind of screw into the ac control, and defrost switch.
Old 09-21-2004, 10:00 PM
mwenz33 mwenz33 is offline
Re: No light at air flow knob
I have the same problem, initially tapping on the dash near the controls would light it back up.. but no more. How do you access it and where... I would hate to break any dash pieces.
Old 09-23-2004, 10:40 AM
phantastic1 phantastic1 is offline
i dont know if you have tried this...but is the dimmer switch turned up all the way?
Old 09-23-2004, 02:03 PM
tenguzero tenguzero is offline
One thing you can try is to just pop out the dimmer control switch. You should be able to just take a flat head to it. Then inspect the wiring behind it, just to make sure there's no short circuits or corrosion or anything. I'm not sure about the fuse thing, but it couldn't hurt to check it. I'm assuming you drive an Accord? (This Accord/TSX hybrid board thing is kind of frustrating.)
(k) TZero publications. All rights reversed. Reprint what you like. Fnord
