Old 09-10-2004, 11:29 AM
dwk617 dwk617 is offline
Send a message via AIM to dwk617
Traction Low Light Keep Coming On
Everytime I Drive My Intrigue Now The Traction Low Light Keeps Coming On Also The Abs And Service Vehicle Soon Comes On I Think Its A Sensor Problem But Im Not Sure.
Old 09-10-2004, 12:35 PM
99Intrigue 99Intrigue is offline
Re: Traction Low Light Keep Coming On
Check the front wheels Vehicle Speed Sensors, behind the wheel.
There's a wheels speed sensor in each of the four wheel hub assemblies and the connectors are supposed to be attached to a small steel bracket to releave tension on the wires but most of them come off the bracket and every time you turn the wheels or go over a bump the whole connector moves and vibrates causing the sensor wires to break.
Try crimping the connector clamp that secures the connector to the bracket making it more dificult to come off.
If the sensor wires are gone your only choice is to replace the vheel speed sensor, along with the bearing/hub assembly.
