Go Back   Automotive Forums Car Chat > Nissan > Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35
Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 Excellent platform and the good ol' VQ30DE and VQ35DE engines.
Old 09-10-2004, 11:21 AM
scoope scoope is offline
Question 1996 maxima does not start on first turn of key
I have this weird problem with my 1996 maxima. When I turn the key, the engine does not start. I turn back the key and try to start it again and the engine starts normally. Should I replace the starter ..could this be an electrical problem or maybe just needs a new battery? Thanks!
Old 09-10-2004, 04:34 PM
BKTerry BKTerry is offline
I have the same problem with my 96 maxima. My check engine light came on and the indication is that both of my o2 sensors may be bad. The problem is intermittent, but still an inconvenience...
Old 09-12-2004, 09:17 PM
VooDu VooDu is offline
Lightbulb 96 maxima not starting
I had the same thing happen. I had an automotive electical guy look at it and he found a short in the wiring in the steering column. It works great now..
Old 09-27-2004, 11:45 AM
zhaomins zhaomins is offline
Checked your fuses? No. 33.
Old 09-27-2004, 12:04 PM
sidzorn's Avatar
sidzorn sidzorn is offline
Send a message via AIM to sidzorn Send a message via Yahoo to sidzorn
Re: 1996 maxima does not start on first turn of key
move the key up and down on the first try common problem is the ignition sub switch
96 gt bbk x-pipe lakewood traction bars american thunder cat back march ram air k&n richmond gears
97 maxima in progress
Old 09-29-2004, 08:49 PM
slickroper slickroper is offline
Send a message via AIM to slickroper
I too have that problem on my 95 max. The thing is, I recently had my starter and battery replaced. My next move is to check the button that the clutch pushes in (I have a manual). I know that if it is not pushed in all the way the car will not start. That is because when you push the clutch pedal in,it pushes a button(inside the car behind the pedal) that allows it to start. Anyways, it is possible that it is dirty or what not and is not properly connecting. Let me know what you think.
Old 09-30-2004, 06:40 AM
sidzorn's Avatar
their also is a little screw by the throttle body that if the two lines aren't lined up that will cause it
