Go Back   Automotive Forums Car Chat > Dodge > Ram Pickup | Ram SRT10
Old 09-10-2004, 09:36 AM
Lonnie K Lonnie K is offline
2003 5.9 L Cummins-No power
My brother-in-law has a 2003 Dodge Ram 2500 w/ 5.9 L Cummins Diesel. It is not the HO. Suppose to generate somewhere in the 220-240 HP range. Has had the truck "dynoed" at an independent shop, and came out w/ 155 HP and 287 ft.lb. torque @ 2800 - 3000 rpm range. Has had the truck into the dealer, and they have tried everything. Changed out computer, all wiring has been checked, fuel pressures, etc. and it has helped. (Should mention truck was @ about 105 HP, when he started this process). Finally, the dealer sent the truck into Cummins, and they confirmed that the truck was about 75 HP short, but said they could do nothing with it, as they could not access through the Dodge computer. Any ideas on what to check next. He bought this truck for hauling purposes, but isn't hauling much, as it sits. Any input would be greatly appreciated.
LK
Old 09-10-2004, 04:08 PM
Gregor Gregor is offline
Can we assume that you have already replaced all fuel and air filters?
Old 09-10-2004, 04:19 PM
Re: 2003 5.9 L Cummins-No power
Yes.
Old 09-23-2004, 11:05 AM
moparboy99 moparboy99 is offline
Send a message via AIM to moparboy99
did they check to see how much boast that it is pulling? dose it had a intercooler. did they check it for leaks and the pipeing. otherwise check and see if they up rate it
Old 10-06-2004, 03:31 PM
fredjacksonsan's Avatar
fredjacksonsan fredjacksonsan is offline
Caution: Monkeys bite!
Send a message via AIM to fredjacksonsan
You said it was dyno'd at 2800-3000 rpm? I know the older Cummins would fall flat on it's face above about 2600 rpm. If your brother is driving the diesel like a gas motor it would seem weaker at high rpms. Have him try shifting at 2300 rpm instead of 3000, see if that makes a difference.
'Course, my 2cents isn't always right.
