Go Back   Automotive Forums Car Chat > Cadillac > Eldorado
Old 09-10-2004, 08:46 AM
latinowarrior latinowarrior is offline
HELP !! battery runs down..
I have a 1984 Eldo Biarittz and it keeps killing the battery. I replaced the battery cable and put in a new alternator. What can I do. HELP!!!!
Old 09-10-2004, 04:53 PM
hyarnell1 hyarnell1 is offline
Re: HELP !! battery runs down..
How old is the battery? It's possible the battery's bad.
Next, look for loads that could drain the battery. Any lights on? Glovebox? Trunk? Courtesy lights?
This vintage Caddy had problems with the HVAC blower module going bad, keeping the fan on after shutdown. Is the HVAC fan on with the ignition off?
Next, with an ammeter in series with the battery, start pulling fuses till the drain stops. That circuit will be the culprit.
harry yarnell
perryman garage and orphanage
perryman, MD
[email protected]
Old 09-13-2004, 08:18 AM
It's a new battery, I have notice that the windshield defrost "blower" is on when I turn on the vehicle even when the climite cotrol is off. How do I check for a bad circuit, I need to rent the proper tools. HELP !! Need to get her going on the road while its still warm out there..
Old 09-13-2004, 08:34 AM
IF the blower module is bad, they're not cheap. I suggest finding a salvage yard that may have a similar GM with that module. Not being familar with the '84 Caddy ( I know Buicks better), I'm assuming it uses a blower control module that GM used throughout the models and years up into the '90s. Where it's located on the '64 Eldo, I don't really know, bur it's usually in the A/C plenum in the engine bay.
As to measuring current draw, if you're unfamilar with this, I suggest finding an independent garage that will do this. The dealer will probably a lot higher in cost.
harry yarnell
perryman, MD
[email protected]
