Go Back   Automotive Forums Car Chat > Volkswagen > Beetle - New/New Beetle Convertible
Old 09-10-2004, 08:32 AM
rtt1969 rtt1969 is offline
Ignition Switch
On my beetle, and the other volkswagens I have had and also a porsche, if the car doesn't start up when you try to start it, you have to turn the key off and then on again to try to start again. Something seems to be blocking it from just starting it like an american or japanese car.
On this 1999 beetle I have, every once in a while when I try to start it for the first time, it will act like that, I will have to turn off the key and then on again, and sometimes 2 or 3 times, before it will let me start it.
Could this be a bad ignition switch, or is there something else that works with the ignition switch that could cause this to happen.
Old 09-10-2004, 04:14 PM
bluebug's Avatar
bluebug bluebug is offline
Re: Ignition Switch
Will it turn over and not start or is it that nothing happens?
Old 09-11-2004, 10:03 PM
boschmann boschmann is offline
Re: Ignition Switch
I think he's talking about the mechanism in the ignition switch to prevent re-engaging the starter after the key has been turned to start once. It is a normal safety feature on Volkswagens. You have to turn all the way back to off before you can re-start.
