Go Back   Automotive Forums Car Chat > Jeep > Grand Cherokee | Grand Cherokee SRT8
Old 09-09-2004, 11:33 PM
dksob81 dksob81 is offline
Send a message via ICQ to dksob81 Send a message via AIM to dksob81 Send a message via MSN to dksob81 Send a message via Yahoo to dksob81
Removing the catatlytic Converter
does anyone have any tips on taking the Catalytic Converter off, I tried heatin git up and pounding it off with no success. I am not trying to ruin it, just want to remove to check it out.
Old 09-10-2004, 05:27 AM
leowolf leowolf is offline
Re: Removing the catatlytic Converter
I dont know but here is a resonable replacement:
http://www.partsamerica.com/SelectPa...tic+Converters
Old 09-10-2004, 05:30 AM
DIY Mechanic DIY Mechanic is offline
To test a catalytic converter you take your fist and bang on the bottom of it.
Hit it like you mean it.
If you hear rust debris or marbles then it is bad.
Otherwise it will sound like thin metal.
There is a heat shield around it so a hollow tin sound is normal.
Old 09-13-2004, 07:50 AM
ByronP ByronP is offline
I used an air chisel to get mine off. If you have an air compressor the air chisel is like $15. I started with the hammer then a bigger hammer then I thought "what am I doing here?" I got out the chisel and it split the pipe like a hot knife through butter. Good luck.
ByronP
I went for a high flow cat from DynoMax.
http://www.jegs.com/cgi-bin/ncommerc...92&prmenbr=361
Old 09-13-2004, 12:58 PM
bryanbrutherford bryanbrutherford is offline
I replaced mine last night,
i used a grinder to make a slit through the pipe, loaded it with penetrating oil and then went to town with a hammer, after a minute or so of pounding it losened up and i was ably to shimmy it by hand and walk it back off the pipe.
of course i used the old sawzall to remove the muffler and other rear exhaust components first.
