Old 09-09-2004, 09:20 PM
rjdavis21 rjdavis21 is offline
99 1500 front differential roaring
help! front diff. is roaring always when movine . doesn't matter if in 2 or 4 wheel . cane someone tell me in the input shaft between transfer case and diff. is supose to turn all the time. mine does and didn't know if this is right.
2 and 4 wheel works fine this in a push putton auto.shift
thanks in advance robbie
Old 09-10-2004, 05:47 PM
Pamsdad Pamsdad is offline
I believe it will turn all the time.
Have you checked the fluid level?
97 Chevrolet CC Dually
00 Blazer
Old 09-13-2004, 07:39 AM
99 4x4 not fixed yet HELP !
checked front greese and was black so something is not right
I check a 97 truck and the front input shaft only turn when in 4 wheel and is free when in 2 wheel.
This 99 truck has 2 wheel ,4 low and 4 high and auto 4 wheel push buttons maybe someone who has a 99 can check for me to see if theirs is free. I need to know if I have two problems. thanks again
Old 09-13-2004, 12:58 PM
Rbraczyk Rbraczyk is offline
Send a message via AIM to Rbraczyk
Re: 99 1500 front differential roaring
I only know this from the blazer forums, but check your transfercase vacuum lines. Sometimes they like to pop off on the electric transfer cases. One reason im happy i've got the shifter.
Old 09-20-2004, 08:19 AM
pulled front ring and pinion and found pitted bearings and also found this post listed below when doing a search
thanks I found my answer
2000 silverado front driveshaft |
icerider []
08-23-2004, 01:13 PM 2000 silverado front driveshaft (Post #1)
My 2000 silverado z71 front drive shaft turns all the time even when it is not in 4wd. Is this normal? Does anyone have a solution?
simple_country_guy []
08-23-2004, 04:41 PM Normal (Post #2)
That is completely normal. You do not have lockouts on the front axle which means they stay connected at all times from wheel to differential to driveshaft. Your transfer case is where the driveshaft disconnects.
Old 09-20-2004, 03:17 PM
got to thinking about last post and thats not what mine does. My front drive shaft turns always with transfer case. I raised rear wheels and in 2wheel drive front shaft and ring and pinion spin with rear wheels ,only the axles are not locked in. anyone know anything else on this. It dosn't seem right to me.
Old 09-20-2004, 09:24 PM
Mikado14 Mikado14 is offline
The front driveshaft should not turn when in 2WD. I believe in your truck you will have 2 actuators. One on the transfer case and one on the front differential. It sounds as though the transfer actuator is froze. I have seen plenty of the fronts freeze up but not one in the transfer case. More than likely is possible.
Remove the actuator and have someone with the key on actuate between 2 HI and 4 HI. the actuator should move back and forth. Also, you might want to check for blown fuses as well as the relays.
If your 99 has the "Service 4WD" light, you might want to have it scanned.
Old 09-21-2004, 11:03 AM
Thank you. i'll post results later
