Old 09-09-2004, 09:53 PM
EskimoMarine's Avatar
EskimoMarine EskimoMarine is offline
Send a message via Yahoo to EskimoMarine
Angry Sunroof problems
All right. Total and complete wierdness. Sunroof won't close all the way anymore. It gets to about... 3 inches from closed and then backs off. It's just like it got caught on something and backs up, saftey feature, I suppose. It used to get to that point and back off every now and then, but now it won't close at all.
I checked the tracks to see if anything was blockin it, but no dice.
Fortunately I live in Southern California, where it rains all of two times a year, but I'd still like to get it to close, for security's sake.
Anybody else have problems similar to this?
(I have a 95 GS btw)
Old 09-09-2004, 09:59 PM
Snowbrdr1122 Snowbrdr1122 is offline
Send a message via AIM to Snowbrdr1122
Re: Sunroof problems
I had the same problem on my 96 GST. All i did to correct the problem was remove the sunroof glass (just a few screws on each side) and then blow the track out with compressed air. If you dont have an air compressor you can use the compressed air in a can stuff. Then I lubed it all up good and it worked perfectly after that. Hope it works for you
2005 Chevy Silverado 1500 Crew Cab Z-71
-Access Roll Top Tonneau
-Cranked T-bars
-285 BFG All Terrains
Next up, 10" lift, rims/tires, and exhaust
Old 09-09-2004, 10:04 PM
spyderman, a picture be much appreciated.
God, I love this place. post isn't up five minutes and I already have two responses
Old 09-09-2004, 10:22 PM
97_3clipse's Avatar
97_3clipse 97_3clipse is offline
Send a message via AIM to 97_3clipse
ok, i did have this problem and it was a stripped gear in the motor ,had to replace it all
1998 Eagle Talon TSi AWD
6 Bolt Swap \ DSMLink V2.5 \ ACT 2100 clutch \ PTE SCM 61 \ Forge MBC@28psi \ VPE O2 Housing \ MR Downpipe \ Thermal R&D Cat-Back \ Tial 38mm WG dumping off O2 \ FMIC w\ in short route \ AFPR setup/walbro 255hp \ PTE 880cc injectors \ Crower Ti retianers \ Crower Springs \ Crower 64414 (stage 3 race) cams \ Ferrea valves \ 3.5 bar MAP \ PLX M-300 Wideband
Old 09-09-2004, 11:13 PM
gthompson97's Avatar
gthompson97 gthompson97 is offline
Send a message via AIM to gthompson97 Send a message via MSN to gthompson97
i've had this problem and what was happening was it was sticking on the slides so i just lubed up the slides with some graphite and it's as good as new.
95 Talon TSI AWD
97 Eclipse GST
Old 09-10-2004, 12:17 AM
joemathews's Avatar
joemathews joemathews is offline
My sunroof sticks too. Except now that it opens, it just doesn't close. At all. So I closed it manually and left it that way .
Seems like I should probably try and fix the problem at some point though....
1996 Eagle Talon
Old 09-10-2004, 03:32 AM
wuman82 wuman82 is offline
Mine had similar problems too, but then I found that my sunroof sliding cover was off its tracks and was getting stuck right before the sunroof would close. So I reseat the sliding cover, and now its all good.
