Go Back   Automotive Forums Car Chat > Jeep > Wrangler
Old 09-09-2004, 08:00 PM
SideShow Sean SideShow Sean is offline
Coil Spacers=New Shocks?Bumpstop extender?
I just put a 2 inch coil spacer lift (TeraFlex BB1T) on my 97 TJ. Do I need to get new shocks or can I get away with the ones on there right now? Also, when I put the spacers in, I left the aluminum bump stop extenders out. Is this OK to do?
Old 09-10-2004, 06:17 PM
goinbig goinbig is offline
Send a message via AIM to goinbig
If you go off-road, the old shocks will limit the suspension travel. However, new shocks are not really required if you stay on the road, or only do light off-roading. You will be fine without the aluminum piece that goes on the axle (for the bumpstops).
Hope that helps
